• 21.11.2026, 16:44
GAqua
Bug: After Update, Flow Sensor connected on Fan 1 of Aquaero 6 no longer works
Sunday, November 12th 2017, 2:31am
I have an Aquaero 6. I just updated to Aquasuite 2017-3.1.
I backed up my settings and updated the Aquaero firmware after the software update. I loaded the previous settings back.
Now the flow sensor that was attached to fan1 is no longer working. It thinks its a fan again.
Sunday, November 12th 2017, 3:27am
The flow sensor have to be connected to the "aquabus low" port now.
This post has been edited 1 times, last edit by "wpuser" (Dec 2nd 2017, 7:57pm)
GAqua
Sunday, November 12th 2017, 6:31am
Thanks, i'll check that out.
GAqua
Friday, December 1st 2017, 8:10pm
The flow sensor have to be connected to to "aquabus low" port now.
This indeed works.
While the notes say that you can still use the Fan-1 port for a flow sensor, this is NOT true. If you only have 2 flow sensors, they have to go to the FLOW port and the AQUABUS LOW ports first.
GTXJackBauer
Saturday, December 2nd 2017, 3:03am
This indeed works.
That's correct.
