• 15.11.2026, 11:17
bas66
help with aquero 6xt d5 pomp
Sunday, November 12th 2017, 4:06pm
I am new with aquero and wan,t to no if i can connect 2 alphacool D5 pomps power from psu and pwm on channel 4 pwm is it possible need a special splitter
wat is the different and sorry for my engels i am dutch
i use a motherboard asus with pwm for pomp i wan,t nothing to my board and i think the flow and temp all the possible and if y must buy 2 new pomps
greetings
Bas
This post has been edited 1 times, last edit by "bas66" (Nov 12th 2017, 4:12pm)
Monday, November 13th 2017, 1:54pm
The only splitter in our shop that would work is splitty9. You can connect the PWM signal of both pumps to one fan channel but it is questionable if you will be able to control the pumps because most PWM enabled D5 pumps use an incomplete PWM implementation which is missing a pull-up circuit for the PWM signal. In such a case it is possible to modify the pump to be compatible. A tutorial can be found here for example.
Similar threads
