• 13.11.2026, 13:21
jacenty
Aquaero LT 6 problem. Windows 10 - Solved.
Wednesday, November 29th 2017, 9:17pm
Hello!
I have a problem with Aquaero LT 6. When I try to connect Aquaero via USB I get a blue screen and "Bad Pool Header" message. Before this I see message "Configuring a new hardware" or something like that. I have Windows 10, mainboard Asus Maximus VIII Gene.
This post has been edited 1 times, last edit by "jacenty" (Dec 1st 2017, 10:43pm)
Wednesday, November 29th 2017, 9:37pm
i think your windows or ar part of your system drivers is broken.
you have to repair your windows.
Try update all drivers, check your bios.
Do not overclock hardware.
CHeck the device with an other computer.
jacenty
Wednesday, November 29th 2017, 9:46pm
Oh I see! I overclocked my CPU. Do you thing this is a problem? I'll try to reinstall system. Thanks for the reply. ;)
GTXJackBauer
Thursday, November 30th 2017, 5:06am
Could be a bad CPU OC. I would follow what Sebastian said and run everything updated and repaired if it needs to be and all on stock settings.
jacenty
Thursday, November 30th 2017, 7:47pm
Should I worry about it? I don't know, what the red light means. I have connected four fans and a temperature sensor. Aquaero works, of course, but I still can't connect aquaero via usb
This post has been edited 3 times, last edit by "jacenty" (Nov 30th 2017, 7:56pm)
jacenty
Friday, December 1st 2017, 10:14pm
Ok, everything is ok. I did what Sebastian said. I mean repair Windows and upgrade drivers mainboard, and now Aquaero works astonishing well. :)
Thanks for reply.
This post has been edited 1 times, last edit by "jacenty" (Dec 1st 2017, 10:19pm)
GTXJackBauer
Saturday, December 2nd 2017, 3:04am
Thanks for reply.
Glad it all worked out. :thumbsup:
