• 02.10.2026, 13:08
darkinners
High Flow usb screw thread size?
Tuesday, February 20th 2018, 2:03pm
I have the High Flow USB sensor, I planning to mount at the bottom of the computer case, I see there are 4 screw hold under the sensor.
Do you guys know what are the thread size of those holes? and how deep? Thanks!
Tuesday, February 20th 2018, 3:35pm
In the web shop description for the usb high flow sensor, it states under technical details:
"Mounting threads: 4x M3, rectangularly arranged at intervals 35 x 44 mm"
As to the depth, open up a paperclip and insert one end into the screw hole.
This post has been edited 1 times, last edit by "InfoSeeker" (Feb 20th 2018, 3:38pm)
darkinners
Wednesday, February 21st 2018, 4:53am
Thanks man!
