• 22.11.2026, 22:50
Philio
How to update firmware on slave unit?
Thursday, April 5th 2018, 1:46pm
I updated my main Aquaero with the latest firmware and it no longer talks to the same unit.
Slave is running fans at 100% constantly which is REALLY annoying!
How do I update the slave so it can talk to the main Aquaero again?
Thursday, April 5th 2018, 2:59pm
You have to put the device into reovery mode, flash the regular firmware first and flash the slave firmware again afterwards.
Steps for recovery mode:
Quoted
26.1. Device firmware deletion and recovery
There a a few exceptional situations which require the device firmware to be
deleted before it can be reprogrammed using the aquasuite:
● The aquaero is programmed with the expansion device firmware.
● A previous firmware update failed, power loss during firmware update.
● Device firmware is corrupt.
Delete the device firmware using the following procedure:
1. Shut down the PC and disconnect all cables from the aquaero except
the power supply.
2. Place jumpers on temperature sensor input 5, 6, 7 and 8.
3. Supply power to the aquaero and wait for approximately 60 seconds.
The device display will show information on the deletion process.
4. Shut down the power supply and remove the jumpers from the tempera-
ture sensor inputs.
5. Connect the USB port of the aquaero to the PC's motherboard and turn
the power supply on.
6. Start the aquasuite software and perform a firmware update.
7. Shut down the PC, reconnect all cables, then reboot the PC.
Make sure to remove all power from the PC when everything is set up. The aquaero will only search for new devices after a fresh start-up. A system shutdown won't help because the aquaero will be still powered through USB.
