• 22.11.2026, 22:24
belia
aquasteam XT on/off
Saturday, April 14th 2018, 12:30pm
Hello,
I looking for a option,
i want to shup down my aquasteam when i don't play video games or when the temperature is under 40degres for exemple.
I don't find is, i think is option is not incluse...?
thx for readind me
Sorry i have a bad english^^
Fieldrider
Saturday, April 14th 2018, 6:31pm
In my opinion it's not a good idea to stop the Waterflow when the PC is on. Even when the components are in idle. They still produce some heat.
belia
Saturday, April 14th 2018, 7:09pm
My watercolling is just for my GPU (graphic card). It's for that i want to shut down my pump when i don't play.
Dundys
Saturday, April 14th 2018, 7:28pm
Like stated above, even if you wont play your game and your system is on idle your GPU(s) are still active and produce ton of heat and before your know it your block(s) will get extreme hot and them you facing problems. Water needs to circulate your loop, even if its very slow, but it has to take the heat away from the hot spot area
This post has been edited 1 times, last edit by "Dundys" (Apr 14th 2018, 7:29pm)
