• 12.11.2026, 21:46
Barnack
cracked pump, cleaning and fixing?
Saturday, July 7th 2018, 7:48pm
hi
last time i put in the inlet tube to the pump i tightened it a bit too much and it got a very small crack where the inlet tube attaches. i noticed because after some time of usage there was a small drop of liquid on the outside near the attachment.
i totally understand it's my fault and not covered by warrantry...
since the liquid i use is a bit greasy, is there any specific product i can use to clean around the crack, and any specific glue i can use to fix it? Was thiniking of plastic specific attack
This post has been edited 1 times, last edit by "Barnack" (Jul 7th 2018, 7:49pm)
Monday, July 9th 2018, 12:17pm
I am not sure if you are talking about the removable pump cover. If so, I would just get a new one. It can be also shipped with a padded envelope for 5.00 Euro.
If you want to glue it I recommend a good epoxy resin adhesive.
Barnack
Monday, July 9th 2018, 1:54pm
No, as i said the crack is where the inlet tube attaches, towards the "outside" of the pump. Picture attached.
The crach is very thin and tight, so thin and tight i cannot be sure to have properly cleaned it, but not thin enough to ignore it, since after some time running there was a liquid drop outside.
Barnack has attached the following image:
Monday, July 9th 2018, 2:04pm
OK, in this area you can only try to glue it. Otherwise you would need a new naked pump without the controller board (can be taken from the current pump).
Barnack
Monday, July 9th 2018, 7:14pm
no need for a specific way to clean eventual greasy liquid leftovers in the crack?
Tuesday, July 10th 2018, 10:00am
You could clean the crack with some Isopropanol. I would apply some of the adhesive directly to the thread of the adapter and afterwards you can work on the crack itself. Put the pump into an oven afterwards. Let it stay there for about 30-60 minutes at about 45°C. This allows the adhesive to settle perfectly in the crack.
