• 12.11.2026, 19:25
Data_Log>Analyze_data chart saving
Thursday, August 9th 2018, 1:20am
Were I to want to copy a Data_log>Analyze_data chart to a new machine, would I be looking to copy the "aquasuite_db.database" file from the existing machine to the new machine?
I know where aquaero profiles and display pages are saved, but not the Analyze data charts.
Thursday, August 9th 2018, 7:01am
you have to copy the database file.
Friday, August 10th 2018, 1:43am
Thank you.
One follow up question, is it safe to copy the database file to another installation of aquasuite?
Saturday, August 11th 2018, 2:47pm
This was timely, I was able to recover from a dumb mistake.
I went into the Data log > Analyze data tab to tweak my chart a bit.
Had intended to load the existing chart, but clicked on the save button by mistake, saving a blank chart over the existing chart.
So I shut down the aquasuite, recovered a previous copy of the database file from backup, copied it over the existing file, restarted the aquasuite & all is good.
I did not notice any thing detrimental from doing this and assume I only lost some recent data from the logger.
A SCREENSHOT of my secondary monitor showing the aquasuite panel.
GTXJackBauer
Saturday, August 11th 2018, 8:22pm
Curious what software are you using for that display? Rainmeter? If so, is it easy to use? I try to stay away from apps that involve lots of programming, etc. I'm looking for the easy way out and love the way Rainmeter funtions with lots of options. I believe I've seen amazing looking desktop backgrounds that were basically the health of the whole system including one's loop and AC's hardware.
Saturday, August 11th 2018, 9:11pm
That is all aquasuite, except the bottom graph which is Networx
Wednesday, September 12th 2018, 2:47am
I think I am finished with my aquasuite panel for the moment.
I am not able to set the gauges as desired, but overall I am pleased with the result.
I would prefer the unit & source text be removable, then I would place the value on the gauge & the source below it
I also would like to be able to control the font size of the numbers around the arch of the gauge
It may not be a big deal, but I know engineers can be picky about accuracy.
The algorithm for the gauge needle display is slightly below value.
The "Air" value is 29,1 but the gauge shows 27,9
The "Fluid" value is 37,3 but the gauge shows 36
The "Flow" value is 3,6 but the gauge shows 3,4
Around a 4% error.
Screenshot of my second/support monitor:
This post has been edited 1 times, last edit by "InfoSeeker" (Sep 12th 2018, 2:49am)
Friday, September 14th 2018, 9:00pm
I found a bit of a work-around for the text (unit/source) automatically placed on the gauge face.
By setting the font size to 1, the text is almost undetectable.
It is not perfect, but works well enough ftm.
novax1
Saturday, September 15th 2018, 9:26pm
hello chosen your comment, if in the size of the text puts 0.1, it disappears completely. :thumbup:
¿But the size of the dial numbers can not be fixed the size? ?(
Sorry for the English but I have to translate. :love:
as the image shows
novax1 has attached the following image:
Monday, September 17th 2018, 11:08pm
Thank you... I had tried zero, which did not work, but did not think to try a decimal number.
Quoted
True, hopefully the software engineers have some time to address the display issues with the gauge object.
Your panel motivated me to add some color using the "Fill" command.
novax1
Tuesday, September 18th 2018, 6:11am
Quoted
hello if you want to visualize the design, here you have on You tube,
regards :rolleyes:
https://youtu.be/GablkZKBmr8
One additional minor mod request
Sunday, September 23rd 2018, 6:51am
It would be useful if the "Statistic Marker" height followed the "Indicator" height setting.
Sunday, September 23rd 2018, 3:54pm
OK, I see my problem, I need to learn XAML.
I looked in the dot.page file and found StatisticHeight settings set to 5.
The only issue then was finding which ones addressed the 3 gauge objects I display, and change to 3.
Got it done, but will be easier once I learn the structure and syntax.
I may even be able to change the font size of the numbers on the gauge arc.
