• 12.11.2026, 11:49
Minor issue
Tuesday, August 14th 2018, 9:37pm
It appears when sensor names are changed in the aquasuite under the aquaero tab, the "Save" icon does not present itself on the aquaero tab.
It can be gotten around by making a change to a controller setting, and then changing back.
I assume sensor names, including virtual and software, should be able to be saved to the aquaero on change?
Thursday, August 16th 2018, 8:32am
That is correct because when you change the sensor name it is saved directly.
