• 08.10.2026, 22:53
ruplikminer
Fans with high power
Friday, October 5th 2018, 2:07pm
Hi!
I have bought the aquaero 6. I have some questions
How much is the MAX POWER per EACH fan channel?
I have 9 fans, each of them use 27.6watts. how can I connect them?
Can I connect the 9 fans power + and - to an external power supply and connect the PWM and the RPM cable all together to one of the fan plugs?
Thanks!
Shoggy NEXT
Tuesday, October 9th 2018, 12:10pm
The maxumum load per channel is 30W and 35W if you also add the optional passive heatsink.
In theory you can also take the power from somewhere else and only connect the RPM and PWM wire to the aquaero. Please note that only one fan can report its speed to the aquaero. If you connect two or more at the same time it will mess up the value.
