• 11.10.2026, 15:28
knacker
Aquacomputer D5 USB/Aquabus pump to motherboard
Friday, October 19th 2018, 12:52pm
Is there a way for me to connect the above to my motherboard to control pump without using my AE6 as I cant fit it in the case anywhere
I am really regretting getting this new case at the minute or can I still use the aquauite without the AE6 being connected?
This post has been edited 1 times, last edit by "knacker" (Oct 19th 2018, 1:08pm)
Shoggy NEXT
Friday, October 19th 2018, 1:34pm
Yes, of course. The connection to the aquaero is only an option.
You can connect the pump directly to an internal USB header of your mainboard.
knacker
Friday, October 19th 2018, 2:07pm
Do you mean I can use the Aquasuite without the AE6 being connected? If so that will give me a little bit of extra room as I am having to crowbar it in :S
Hufeisen
Friday, October 19th 2018, 5:06pm
Yes.
knacker
Friday, October 19th 2018, 8:44pm
Thanks for that
Jakusonfire
Monday, October 22nd 2018, 11:20am
The only difference is that you will only have manual style, fixed speed controls through aquasuite instead of being able to add the pump to an automatic controller that the Aquaero uses aquabus for, or control the pump through the Aquaero of course.
This post has been edited 1 times, last edit by "Jakusonfire" (Oct 22nd 2018, 11:22am)
Similar threads
