• 22.11.2026, 22:06
selvakumar1989
DIFFERENCE BETWEEN aquaero 5 XT VS aquaero 6 XT VS aquaero 6 PRO
Monday, November 26th 2018, 5:18pm
:)Hi guys im new to this forum and i have placed order for aquaero 6 XT black panel with red led whats the difference between all this version
GTXJackBauer
RE: DIFFERENCE BETWEEN aquaero 5 XT VS aquaero 6 XT VS aquaero 6 PRO
Monday, November 26th 2018, 9:25pm
AQ 5 is the older versions of the 6. 6 is better all around as it can handle the loads better per channel. 6 Pro vs XT, XT has touchscreen and Remote vs Pro.
Tuesday, November 27th 2018, 9:20am
aquaero 5 uses a classic analog voltage control which can generate a lot of heat. The power per fan channel is limited to 20W and the overall power is limited to 60W.
aquaero 6 uses switching regulators that produce almost no heat due to their very high efficiency. The power per fan channel is limited to 30W and there is no overall power limit.
Other than the aquaero PRO, the XT series has a touch screen with four programmable buttons in addition, the three main buttons are illuminated, the display is covered by an additional glass and the remote control is included.
selvakumar1989
Thursday, November 29th 2018, 7:00pm
Thanks for the quick reply
selvakumar1989
Thursday, November 29th 2018, 7:08pm
whats the max number of fan it can support 6XT
Thursday, November 29th 2018, 8:47pm
This can not be answered in a useful way because it depends on the power consumption of the fans that you connect.
selvakumar1989
Tuesday, December 4th 2018, 2:42pm
what im asking is whats the max individual fan each PWM fan header can handle
had i have ordered
aquaero 6 XT black/red With [b]Passive heat sink for aquaero 6 and [/b]Real Time Clock expansion module for aquaero 5 und 6 does the clock module can be fitted after fitting the headsink
Tuesday, December 4th 2018, 4:10pm
The aquaero 6 can handle 30W per fan channel. With the passive heatsink 36W per fan channel are possible.
The RTC module can be also installed when you use the passive heatsink. The heatsink comes with short distance pieces in addition to allow the installation of the RTC module.
selvakumar1989
Saturday, December 8th 2018, 5:04pm
thanks for the reply but im new to the aquaero 6 XT i need detailed user manual im using HWinfo 64 bit need your support i googled can't find any information only singularity computer posted some review but i need detailed software information
Sunday, December 9th 2018, 9:58am
aquaero manual
selvakumar1989
Sunday, December 9th 2018, 10:46am
i already had the manual downlaoded but i need detailed guide how to setup system with HWinfo 64
mditsch
Sunday, December 9th 2018, 11:23am
Nothing special to do. Aquasuite will automatically detect an installed HWInfo when Aquacomputer Service is running.
as an example a screen print from my data quickview with detected HWInfo64
selvakumar1989
Sunday, December 9th 2018, 2:09pm
thanks for the quick reply im impressed by the forum user and admin speed in responding keep going :)
Similar threads
