• 06.10.2026, 14:06
Maki911
Is it possible to connect two D5 Next pump in serial config?
Friday, January 25th 2019, 5:46am
Hi everyone, I've bought two d5 next pumps,and I was wondering can I connect them in serial config? Will that impair sensors function?
II ARROWS
Monday, January 28th 2019, 12:29am
You should be fine, just don't expect 2x perfomance.
I would have chosen another pump if you need the extra flow, but it should work.
The sensors are independent, they just see the temperature and flow at their point, if they are in serial one directly after the other, you should basically see the same value on both (within measure error).
Similar threads
