• 12.11.2026, 18:29
Crazy-Carl
53068 Flow sensor?
Sunday, February 17th 2019, 11:55pm
I have a 53068 flow sensor that will be plugged into my Aquaero 6 Pro. The 53068 will be placed further on in my loop just to see how flow rate is away from pump.
Has anyone tried this? I have ordered a D5 Next pump, will it read flow rates correctly?
Thanks;
Crazy-Carl
This post has been edited 1 times, last edit by "Crazy-Carl" (Feb 17th 2019, 11:58pm)
Monday, February 18th 2019, 2:26am
The D5 Next product description states:
Quoted
The accuracy does not match the accuracy of an external flow sensor, but is entirely sufficient for monitoring purposes.
Your flow sensor will produce the more accurate results, for what that's worth.
And the flow sensor may be placed anywhere in the loop and it will yield the same result, as the coolant flows at a constant rate throughout the loop.
Crazy-Carl
Monday, February 18th 2019, 11:08pm
Thanks INFO :)
This post has been edited 2 times, last edit by "Crazy-Carl" (Feb 18th 2019, 11:12pm)
Similar threads
