• 19.11.2026, 10:19
BillLucas
6XT screen removal.
Tuesday, March 12th 2019, 5:14pm
Hey guys.
Ive had my aquaero 6XT many years and its been fantastic. However these days with the large number of cases coming out sans-5.25 inch bays I was considering removing the screen portion to turn my XT into essentially a 6LT. which seems more economical than buying a 6LT and wasting the 6XT. I am competent hardware/disassembly wise.
I was wondering if anyone has done this before?
Does it effect the firmware/updating the firmware at all?
Would any functions (apart from the obvious) be lost?
Thanks in advance, Bill. :)
Tuesday, March 12th 2019, 5:46pm
You can remove the display without any issues. It will be detected by the aquasuite as a LT after the removal.
As it will be detected as a LT you are loosing one year free software updates at the aquasuite. To prevent this you need to install the display any time you need to do a update of the aquasuite.
After the update it can be removed again. This is the only issue downgrading to the LT.
OutSider
Saturday, March 30th 2019, 7:53pm
Thanks for this info. I've been running mine without the screen since I got it, though it's only been a few months maybe, still this is good to know and I'll make sure to attach the screen before I update again.
