• 08.10.2026, 11:53
harlock328
aquasuite 2018-11 not seeing D5 pump correctly
Friday, April 26th 2019, 1:30am
I just installed aquasuite 2018-11; was running 2016 before. After install the D5 pump settings are not working. show rpm 0; percent 0 amp -- . all hardware updated to current firmware
harlock328 has attached the following images:
This post has been edited 2 times, last edit by "harlock328" (Apr 26th 2019, 1:53am)
Friday, April 26th 2019, 9:54am
reset all mps devices (with usb connection) to factory defaults, and set up ist new and give each device an individual aquabus address.
After changing some aquabus depend settings you have to power down/up your system.
harlock328
Saturday, April 27th 2019, 12:14am
Not sure if I understand. I clicked on factory default for the mps and didn't do anything. I also did it for the aquaero. Shut down pc..unplugged it for 60secs. started it back up same as was before. The D5 is connected to aquaero via aquabus. Do I need to connect it to the usb header also to get this to work again?
Thursday, May 2nd 2019, 7:54am
Yes, you have to setup each device via USB before you can use it with aquabus.
