• 19.11.2026, 14:35
30H6
Best Practices ? - What Data To Monitor
Thursday, May 30th 2019, 9:44pm
I am new to the water cooling scene and aquasuite as a whole. Does anyone have a list of settings for what they monitor that they would share and why?
Thanks
Gregory
Hufeisen
Friday, May 31st 2019, 4:58pm
Water temperature and Flow rate.
If the water temperature is too high, it can cause a failure of the pump or tubes.
The maximum water temperature is between 45°C and 55°C, depending on the components used.
If the Flow rate is too low, the tempratures of the CPU/GPU get very high and can cause problems.
Minimum flow rate should be 30 Litre / hour.
Similar threads
