• 10.10.2026, 08:30
REDG
Connection Aquaero and VFD-Display
Saturday, December 11th 2004, 6:37pm
The Aquaero 3.07 VFD-Display is composed of Aquaero LT and VFD-Display.
What is the type of connection between the Aquaero and VFD ??? It is possible to off-set the VFD of the Aquaero ???
I would like to integrate the VFD-Display into this case :o
Thanks :D
M'en Bati Sièu Nissart
x-stars
Re: Connection Aquaero and VFD-Display
Saturday, December 11th 2004, 9:25pm
The Display is connected directly on the Ae, but it would be no problem to use a cable (for example an old ide-kabel). The only problem would be, that you won't have any warranty.
cya
x-stars
r1ppch3n
Saturday, December 11th 2004, 9:36pm
the displays are directly soldered onto the ae
but if you don't care about warranty i don't see any problem there ;)
REDG
Sunday, December 12th 2004, 9:07pm
Why no warranty ???
If I buy aquaero LT and VFD-Display separately, I have warranty on each material :P
Of course if I burn the equipment by welding my cable no warranty, but if not ...
The Silverstone 2x16 VFD-Display and the Noritake 2x20 VFD-Display are in parallel.
So, it is possible to connect the Silverstone VFD-Display to the aquaero LT ???
