• 12.11.2026, 01:15
Lanc
Aquacomputer aqualis XT 450
Monday, June 3rd 2019, 7:52pm
Hello.
I have a question, can i make to work it hotizontally?
If someone knows please tell me what inlets and outlets should i use.
I can mount it on two holders, but im not sure if flow will be ok and if it will not leak?
What is stainless steel deflector for?
Should i use acrylic plate or deflector if I want to use top inlet and bottom outlet?
This post has been edited 1 times, last edit by "Lanc" (Jun 4th 2019, 3:10am)
Wednesday, June 5th 2019, 8:29pm
I believe you can make the reservoir work, but you are paying for features with the XT that will not function in the horizontal mode.
1. the "fountain effect" is gravity driven and will just flow down the top with no visual effect.
2. the "fill level sensor" will not function properly because the water column measured, if any, will not reflect the water volume.
If you use a reservoir in the horizontal mode you should be able to seal it so it will not leak, but you should have the suction port rotated to the lowest possible position, and run it as full as possible.
I believe the deflector plate is for the case of not using a bottom port (not fountain effect or a top port) for a return, which reduces vortexes & air suction into the supply port.
This post has been edited 1 times, last edit by "InfoSeeker" (Jun 5th 2019, 8:30pm)
