• 18.11.2026, 21:49
Pirazy
Aquaero 6 Pro problem with controlling PWM fans
Wednesday, June 5th 2019, 8:51pm
Just got my new build booted up with an Aquaero 6 Pro controlling 18 PWM fans through two splitty9 and can't for the life of me figure out the software or how to accurately control the fans.
I get no rpm-reading no matter if I set the control method to Power, Speed or PWM, occasionally a number flickers up and then it goes down to 0 again.
I've set the jumper on both splitty9 to be controlled by aquaero.
The only way I can control the rpm of the fans is to adjust the maximum power slider.
Bartdude
Thursday, June 6th 2019, 5:57am
so 9 fans on 2 channels through 2x splitty9, what make/model are the fans?
RE: Aquaero 6 Pro problem with controlling PWM fans
Thursday, June 6th 2019, 12:53pm
If you have the jumper set to "aquabus", then it's wrong.
That is for splitting the aquabus communications bus, which connects all 4 wire for all ports.
You want the other jumper setting, which will only forward the RPM signal for the port marked RPM.
Similar threads
