• 12.11.2026, 03:11
INACIO JUNIOR
The device has USB
Saturday, June 29th 2019, 5:46pm
All cables are connected, including USB, and I'm getting this message.
::.I7-10700k 5.1 Ghz | Asus Maximus XII Formula | GTX 1080 Ti ASUS POSEIDON.::
::.32GB Corsair Dominator Platinum RGB 3000 Mhz | WaterCooler Custom.::
::.Teclado MadCatz S.T.R.I.K.E.7 | Mouse M.M.0.7.::
::.2X SSD HyperX Savage x 250GB RAID0.::
::.Fonte Corsair AX1200W | Cosmos II.::
Saturday, June 29th 2019, 6:36pm
your windows is not able to detect the usb device.
this is an usb or windows problem.
INACIO JUNIOR
Saturday, June 29th 2019, 9:40pm
What should I do?
Sunday, June 30th 2019, 1:30pm
Are you using a USB hub? if so, try direct connecting to the motherboard for a test.
Also, be sure the polarity of the USB cable connectors is correct on both ends.
The PSU powering the motherboard is the same one powering the aquaero (same PSU for both)?
INACIO JUNIOR
Tuesday, July 23rd 2019, 8:13am
Ok, problem solved, thanks. ;)
