• 22.11.2026, 09:09
vixerunt
Aquastream Ultimate and Aquaero 6 LT
Friday, September 13th 2019, 2:19pm
As I can see, connecting Aquastream Ultimate by aquabus to Aquaero 6 LT has a result of loosing some important features like creating curve controller of the pump! Am I right or, maybe, I did something miss?
Saturday, September 14th 2019, 1:38am
You are right, the aquabus connection places the device under the control of the aquaero, and you use the curve controllers on the aquaero.
The downside is the aquaero does not gain additional curve controllers, so you loose the total available controllers overall.
It's the same with the quadro, farbwerk, farbwerk 360, etc.
Personally, on aquacomputer devices that have a USB connection, I generally do not use the aquabus connection if one is also available... but that's me.
vixerunt
Saturday, September 14th 2019, 9:31am
Yes! But in my case I can not use USB because my motherboard ASUS ROG Zenith has just one USB 2.0 connector on board and doesn't allow to use USB splitters with Aquastream Ultimate.
GTXJackBauer
Saturday, September 14th 2019, 10:27am
Just use a HUBBY7.
vixerunt
Saturday, September 14th 2019, 8:51pm
Just use a HUBBY7
I did think about it, but am afraid to buy it before testing, because of ASmedia USB-hub peculiarities. Three hubs of others firms I tested worked with errors.
GTXJackBauer
Sunday, September 15th 2019, 6:34am
Just use a HUBBY7
Just use all HUBBY7s. Solid build and well worth it. I use two of them in a chain currently. No issues.
vixerunt
Sunday, September 15th 2019, 12:06pm
OK! Ordered! Am waiting!
