• 01.12.2026, 00:03
Anon5710
Overview New H2O setup
Sunday, December 12th 2004, 10:40pm
Hi :)
Ive been thinking about a H2O setup for some months now but ive decided to really go do it :) (since my current setup is just ay to noisy  :-/ )
I will buy these things now and the other later.
WaterBlock CPU       :  cuplex PRO Halterung Athlon64                                                           47.49
Reservoir            :  Ausgleichsbehälter aquatube Rev. 1.1 blau + aquabay at Rev. 1.5               67.98
Pump                 :  aquastream Pumpe 12 V Rev. 3.0                                                            74.99
Radiator             :  airplex evo 240 + airplex evo Einbaublende 240 + 2 x Papst 4412 F/2GL 104.6
Tubing               :  Schlauch PUR schwarz plugncool 5m                   8.50
Total cost :                               303.56
Now ive got some questions:
-Wthell is plug and cool gerade ?
-IS that Pump good enouf for everything ? (including the "later" part?
-Is the radiator good enouf? (for now and later)
-Is the radiator easy to build in ? (i have a CM STacker ;D )
-Is there anything i should buy (like clamps etc... ?)
Thats about everything i had to say :)
Later
WaterBlock Chipset   :  twinplex Rev. 1.2                                   38.99
WaterBlock GPU       :  aquagratiX800 Komplettkühler X800-Serie             61.90
Waterbay HD              :  Festplattenkühler aquadrive blau                    79.99
Anon5710
Re: Overview New H2O setup
Quoted from "Anon5710"
Hi :)
Ive been thinking about a H2O setup for some months now but ive decided to really go do it :) (since my current setup is just damn to noisy  :-/ )
Total cost :                               303.56
Later
WaterBlock Chipset   :  twinplex Rev. 1.2                                   38.99€   (*)
WaterBlock GPU       :  aquagratiX800 Komplettkühler X800-Serie             61.90€   (**)
Waterbay HD              :  Festplattenkühler aquadrive blau                    [b]79.99€   (***)
pharao
Sunday, December 12th 2004, 11:02pm
1.
gerade = unbowed
gewinkelt = bowed
Plug and Cool (PnC) is the connection-system used by AC.
2. Yes, the Aquastream is absolutely sufficient.
3. Yes, the Radiator is enough, too. You even can run the fans at 5 or 7 Volt.
5. maybe some angles
in some corners you really might need 'em.
and I'd advise ACFluid (against the corrosion)
Anon5710
Monday, December 13th 2004, 7:39pm
with my really bad german i didn't really understand on how to add h2o or anything else in to your setup.. since your reservoir in an 5.25 inch bay.
Or is this thing your second reservoir ?
Ausgleichsbehälter aquainlet für aquastream und Eheim 1046/1048 aus Aluminium Wich is easyer to fill ?
And how the hell do you let the water out than ?
NikoMo
NikoMod
Monday, December 13th 2004, 7:49pm
you can let the water out, by installing a t-connector at the lowest position in your system. ad some hose and a closing-connector.
install wether a second t-connector and closing-connector at the top or just open your aquatube if its at the highest point in your pc.
@ shoggy
what is the word for ?
Monday, December 13th 2004, 8:06pm
Schlauch = hose
And hose is the german word for trousers ;D
pharao
Monday, December 13th 2004, 8:18pm
Lay the PC on its back in order to fill the water in
Nitrix
Tuesday, December 14th 2004, 12:39am
NikoMo: thats a Valve m8  ;D
Anon5710: if you still have issues you can add me to your msn and i can talk you through it
ddpeggman [/AT\] hotmail.com 8)
Yellowsnow17
Tuesday, December 14th 2004, 7:33pm
I think a good question was asked. How many blocks can a 240 cool effectively. And how many blocks can a single Aquastream handle?
@ Shoggy:
My personal favorite translation is "Gift." In German it is poison but in English it is a "geschenk" or "present" I'd rather have an English Gift than a German Gift! ;D
Ich bin Ausländer und sprechen nicht gut Deutsch
Nitrix
Wednesday, December 15th 2004, 1:44am
I would say thet the 240 would effectively cool ALOT of blocks. I recently fitted a dual processor system with AC kit I.e gpu/ 2 cpu/ mobo/ hdd +psu all cooled with good temps and this is all run off one aquastream 8)
Anon5710
Wednesday, December 15th 2004, 3:42pm
Okey after alot of questions and getting great answers (Thanks Nitrix ;D ) ive decided to get the next things. But still be free the make some comments ;)
CPU WaterBlock
**cuplex PRO Halterung Athlon64
reservoir
**Ausgleichsbehälter aquatube Rev. 1.1 blau
**Einbaublende Aluminium schwarz eloxiert für den aquatube
**Einbaublende Aluminium silber eloxiert für den aquatube
**aquabay at (Einbaurahmen für die Laufwerksschächte) Rev. 1.5
Pump
**Aquastream Pumpe 12 V
radiator
**airplex evo 240
**airplex evo Einbaublende 240
**Papst 4412 F/2GL
**Papst 4412 F/2GL
misc
**Arctic Silver 5 Premium High-Density Silver Thermal Compound
**ACfluid - farbloser Korrosionsschutz
**Kugelhahn plug&cool Metall
**T-Verbinder plug&cool Metall
This comes down to about EUR 313.92
NOw ofcours there is still some stuff missings like tubing so ive got some questions left :)
-How many meter tubing is required ?
-What kinda plugs do i have to take for the aquatube/rad ? (plug&cool gerade/gewinkelt)
-What kinda plugs does the pump needs? (You have to buy that seperatly)
-How many extra bowed plugs schoul i take ? (or straight?)
Lay-out how i will be doing it :)
I will modify my the upper panel from my case (cm stacker) to something like http://www.aquamods.pwp.blueyonder.co.uk…lianradtube.jpg
The other aquatube will be put in to the aquabay, along with the aquastream than to the parts that need to be cooled :)
Is this a good setup : rad -> reservoir -> reservoir -> pump -> cpu -> ... -> ... -> reservoir ?
(the ... are future components)
Greetings Anon5710
;D
