• 16.11.2026, 08:22
shaibg
Get parameters in case the aquesuite is closed
Monday, November 18th 2019, 1:35pm
There is an ability to get data (e.g temp from the sensors) in case the aquasuite application is closed (NOT MINIMIZED)?
Thanks!
Thursday, November 21st 2019, 1:08am
Not exactly sure what you are looking for, but were I to assume you want the aquaero to continue to function, once setup, with the aquasuite closed, then yes, it will.
Undesirable
Thursday, November 21st 2019, 4:27am
I think he means the software sensors.
Thursday, November 21st 2019, 5:41am
I was curious about the Virtual Software Sensor, and my test showed the Virtual Software Sensors from the Playground to be persistent.
I was using a Virtual Sensor from the aquaero to drive an LED Controller to reflect the coolant/air delta.
I made a duplicate Virtual Software Sensor in the aquasuite playground and substituted it in the controller.
The controller functioned the same with the aquasuite open, minimized, or closed.
I even rebooted the system without autostarting the aquasuite, and the controller functioned as expected.
Thursday, November 21st 2019, 7:46am
Softwaresensors, hotkeys, Virtual Sensor, Hardware Monitoring, Ambientpx, Sound ... is processed in the aqua Computer Sevice. The aquasuite is only the UI.
eliranM
Tuesday, December 17th 2019, 7:45am
i am having the same problem.
1. Iv'e configured via "Automatic data export" tab the file path and XML type selection.
2. Added Data sources from aquaero/Temperature sensors, and selected the relevant software sensor
Results:
only when aquasuite app is open the xml file is updated.
Tuesday, December 17th 2019, 11:23am
Logging and exports only working when the aquasuite is running.
Similar threads
