• 11.11.2026, 16:31
Dundys
Hubby7
Sunday, November 24th 2019, 3:23pm
Hey everyone,
I need to expend USB2 and first thing crossed my mind was to get hubby7, but before I order I need to know whether I can use
longer USB cable. Hubby comes with 25cm internal cable and that's going to be
short so I was thinking of using: https://shop.aquacomputer.de/product_inf…roducts_id=2573
I don't see a reason for not been able to but I would like to be sure.
Your advice would be greatly appreciated Thanks
This post has been edited 3 times, last edit by "Dundys" (Nov 24th 2019, 4:42pm)
knacker
Sunday, November 24th 2019, 5:21pm
I use similar cable with mine and no real problems so far
GTXJackBauer
Sunday, November 24th 2019, 5:47pm
I don't see why not and if there's ever an issue, you could self power it so the signal doesn't weaken.
On mine, I've chained two HUBBY7s in close proximity of each other since I ran out of USB 2.0 headers so I powered the 2nd one, last in the chain to make sure everything gets some power and the signal stays healthy. No issues here after doing that.
This post has been edited 2 times, last edit by "GTXJackBauer" (Nov 24th 2019, 5:48pm)
Dundys
Sunday, November 24th 2019, 8:05pm
Thank you guys for the confirmation. I just got new internal multi card reader that needs to be connected to internal USB2 in which both are already occupied, so hubby will be very handy.
Thanks again
GTXJackBauer
Monday, November 25th 2019, 6:33am
No worries Dundys and great hearing from ya. :thumbup:
Dundys
Saturday, November 30th 2019, 7:20pm
OK, I'm facing some issues, can you guys give a hand, Aquaero is not detected. I connected main USB cable from M/B to hubby 7 power USB, then from hubby I have USB cable going to aquaero and another USB cable to card reader, am I off here somewhere, it seem simple and should work
Dundys
Saturday, November 30th 2019, 7:59pm
Alright, got it working :D cables on hubby where not correctly installed and jumper was set incorrectly, working great now. I will post just sneak preview of the workstation build I'm almost done, its purely on air, but..... well, I will let you be the judge, Its freakishly loaded 8o
GTXJackBauer
Sunday, December 1st 2019, 1:08am
I was just going to say to make sure your connections are installed properly as they easily can be put together incorrectly by mistake. Glad you got it working now. :thumbsup:
Dundys
Thursday, December 5th 2019, 5:33am
Can you see Hubby squeezed at the bottom of the first picture, It doesn't seem to bad but really, there is no room for anything else :D
This is 24/7 running workstation, no pampering 8o
Dundys has attached the following files:
  • IMG_7118-min.JPG (496.26 kB - 170 times downloaded - Last download: Oct 1st 2026, 2:44am)
  • IMG_7113-min.JPG (459.56 kB - 157 times downloaded - Last download: Oct 29th 2026, 12:11pm)
  • 20191204_212214-min.jpg (544.44 kB - 156 times downloaded - Last download: Oct 28th 2026, 8:50am)
This post has been edited 5 times, last edit by "Dundys" (Dec 5th 2019, 5:42am)
