• 15.10.2026, 14:04
Elior77
Aquasuise X.11 and X.4 bug report
Friday, January 3rd 2020, 9:35am
Hey,
If this is not the right place please move it, thank you.
X.11 bugs:
1. QUADRO->FANS->FAN SETUP->"i" items does not work.
2. QUADRO->SENSORS when adding something that is not a temp sensor (cpu usage) it will not show up when choosing "Controller source".
X.4 bugs:
After installing and using X.11 I tried X.4 - It gave a massage about firmware update needed but the button did nothing.
Thanks !
Elior
Friday, January 3rd 2020, 9:49am
1. for fan controllers only temperatures are allowed as data source.
2. you can not downgrade the firmware (from X11 -> to X4, read the error message)
Quoted
??? make screenshots or explain what you mean.
Elior77
Friday, January 3rd 2020, 10:01am
1. I can use "CPU usage" as data source - and if it was not meant to be, it should - it is a very nice option.
SS attached.
The only thing left to do is change the labels "Minimum temperature" "Maximum temperature" to "Minimum value" "Maximum value" or just "Minimum" "Maximum".
2. How come I can not downgrade ? If I do not like the bugs on the insider and want to go to the stable release - Normally I could. btw no error massage...
3. SS attached - but nothing much to see - the functions in the window does not work - I can move the sliders but nothing happens.
4. When powering on the PC the fans go 100% until the AC service comes on - is there any way to control it ? maybe set it a lower then 100% ?
Thanks !
Elior77 has attached the following images:
Friday, January 3rd 2020, 10:27am
This is the normal behavior.
You can move the slider an see the dependency between Controller Output and the Scaled Fan Output. This is a preview, nothing happens on you device.
No, this is not possible
Dundys
Thursday, January 9th 2020, 4:12pm
Just downloaded new x11 aquasuite and before I go forward upgrading firmware I would need to know if after all there is an option to disable from profiler to load with windows and what other benefits are from upgrading to x11 from X4. I don't want to upgrade firmware and be lack to it.
Never mind, found it:)
This post has been edited 1 times, last edit by "Dundys" (Jan 9th 2020, 4:17pm)
Dundys
Friday, January 10th 2020, 7:20am
Aquasuite X11 keeps on stopping services, It's not blocked by firewall that's for sure. After restarting as a admin and starting services again It runs for a while and then stops services again.
I'm on Windows 7x64
Dundys has attached the following image:
Friday, January 10th 2020, 7:23am
Restart the computer after the update is finished. When the sevice is stopped send us a creshlog from the windows event viewer.
Dundys
Friday, January 10th 2020, 7:27am
Thanks I will do that. Although I haven't used your services in a while, where exactly do I sent the log.
Thanks
Friday, January 10th 2020, 7:44am
When the aquasuite or the service crashes, windows generate 2 entries in the system log -> Eventlog, Windows Protocol, Application.
Export the logs and send the log with a short description to info@aqua-computer.de
Otherwise we cant fix bugs.
here is the correct topic for feedback an Bugs:
New: aquasuite X
