• 22.11.2026, 18:38
Andrei
OCTO: Ambientpx doesn't work on 90 leds (6 strips)
Tuesday, February 11th 2020, 6:28pm
Hello everybody.
I'm new owner of OCTO controller and faced problem with Ambientpx lighting. It doesn't work with 90 leds on one RGBpx output.
Introductory:
1) OCTO controller, 1002 firmware
2) Aquasuite X.11 20.12.2019
3) 6 RGBpx strips connected in chain correctly
4) Each strip can be controlled by Aquasuite, any led mode works correctly except Ambientpx
5) Led config:
Here is photos:
This is Ambientpx mode for 90 leds (config above). Mode works only for full 4 stripes and 4 leds on fifth stripe - 64 leds summary. Next 26 leds are always dim red.
At the same time i can switch mode for 5 and 6 stip and they will work correctly.
So:
1) Am i doing something wrong?
2) Is this a bug?
3) Is there 64 led limitation of Ambientpx?
Thanks.
This post has been edited 1 times, last edit by "Andrei" (Feb 11th 2020, 6:31pm)
Wednesday, February 12th 2020, 2:49pm
Thank you for report this bug.
I can confirm this is a bug in the OCTO firmware. The bug will be fixed in the next aquasuite release.
Andrei
Wednesday, February 19th 2020, 6:23pm
Last update fixed problem. Thanks.
Similar threads
