• 10.10.2026, 01:16
Vankrom
Want to be sure of something before I order my loop parts.
Tuesday, February 11th 2020, 9:55pm
I am working on a water cooling loop and intend to use the D5 next. I will be using a total of 7 noiseblocker B12-P 120mm fans.
I am hoping that I can connect a splitty9 / splitty9 active to the D5 next and have the fans respond to accordingly.
Am I right in this assumption or am I missing something
Thanks in advance! :D
p.s is the d5 next compatible with the heatkiller tanks?
DRF
Tuesday, February 11th 2020, 10:00pm
Hello i dont know if i understood your question but with splitty9 you distribute power + 1 single PWM signal for every slot and retrieve 1 Tachy signal back
Vankrom
Wednesday, February 12th 2020, 3:05am
Just wondering if the D5 next will have enough power to run the 7 fans or if i need the boost granted by the splitty9 active.
kandrey89
Wednesday, February 12th 2020, 3:35am
https://www.blacknoise.com/datas/downloa…0_122012_de.pdf
B12-P has 1.92W consumption, so 7*1.92=13.44W and you have 25W fan power. So yes D5 Next should be able to power your fans!
ehupp01
Wednesday, February 12th 2020, 5:51pm
Had mine setup with 8 fans and they could not reach full RPM so I added a Silverstone 8-Port PWM Fan Hub and it works great. I think the splitty9 would be a good choice also.
Vankrom
Friday, February 14th 2020, 7:39pm
Was that a regular or the "active" splitty9?
ehupp01
Saturday, February 15th 2020, 4:00pm
Did not use Splitty9 I used the Silverstone 8-Port PWM Fan Hub that is similar to the Active it is powered. :thumbup:
This post has been edited 1 times, last edit by "ehupp01" (Feb 15th 2020, 4:02pm)
Vankrom
Wednesday, February 19th 2020, 12:21am
Not got any experience with Silverstone products. Reliable?
ehupp01
Wednesday, February 19th 2020, 8:29pm
So far so good. First one I owned as well. :thumbup:
