• 12.11.2026, 18:09
smud
kryoM.2 difference between two water blocks
Monday, February 17th 2020, 12:50am
https://shop.aquacomputer.de/product_inf…roducts_id=3401 <- which plated this one?
https://shop.aquacomputer.de/product_inf…roducts_id=3408 (nickel plated water block)
I didn't find information about https://shop.aquacomputer.de/product_inf…roducts_id=3401 , seems it's copper by images but I wonder why it's cheaper than nickel then? I though copper has better heat sink than nickel or?
Monday, February 17th 2020, 5:08am
I believe both are copper, the nickel version has a nickel plating applied, hence the additional cost.
smud
Monday, February 17th 2020, 3:39pm
Isn't it pointless to do then - adding nickel over copper since copper has better heat sink? 8| ?(
eisbehr
Monday, February 17th 2020, 3:55pm
Some like silver plated coolers more than a copper surface. ;)
And the plating protects the copper for oxidation.
Monday, February 17th 2020, 4:47pm
What eisbehr said... plus, the heat transfer lost across the very thin nickel layer is minimal.
But, for the purist, aquacomputer does provide the naked copper option.
Many people have paint on their radiators, not an optimal solution, but an aesthetic trade-off.
It's all about personal preferences, capitalism at work :)
Hufeisen
Monday, February 17th 2020, 6:08pm
Nickel plating is required if you want to use Liquid Metal as thermal paste.
This post has been edited 1 times, last edit by "Hufeisen" (Feb 17th 2020, 6:10pm)
eisbehr
Monday, February 17th 2020, 6:25pm
As we learn step by step, everything is there for a reason! :D
smud
Monday, February 17th 2020, 6:54pm
I don't think what you can apply liquid metal for these M.2 water blocks :D
Similar threads
