• 22.11.2026, 23:01
cristian.ticu
MPS Sensors Internal Leak
Tuesday, March 10th 2020, 12:10am
I have two brand new MPS Pressure Sensors Delta 100.
Both of them are leaking internally,not at the fittings but at the internal gasket/sensor interface.Got them installed on two separate loops to monitor some filters. The water flow is about 100l/h on each loop, measured with MPS flow sensors witch are not leaking.
I can understand one to be defective, but two?
Tried swapping the tubes, tought maybe I got High/Low ports mixed, still leaks. Is something I'm doing wrong, or should I call for replacements?
This post has been edited 1 times, last edit by "cristian.ticu" (Mar 10th 2020, 6:40am)
ehupp01
RE: MPS Sensors Internal Leak
Tuesday, March 10th 2020, 2:33am
100l/min wow ;( are you sure its not 100l/hr. That might be your problem, what kind of pressure are you building?
Both of them are leaking internally,not at the fittings but at the internal gasket/sensor interface.Got them installed on two separate loops to monitor some filters. The water flow is about 100l/min on each loop, measured with MPS flow sensors witch are not leaking.
