• 10.10.2026, 15:20
mikegray
Place 70 cm temp probe (PN 53026) in the reservoir?
Sunday, March 15th 2020, 10:34pm
I have an EK Fluid Gaming system I'd like to set up with a QUADRO, then base the radiator fan curves on water temps.
You can't use a g1/4 type probe with a fluid gaming system because EK FG loops are aluminum based, and adding a non-alu component would lead to corrosion.
However, I DO have an upright cylinder reservoir and a whole bunch of those skinny 70 cm probes lying around. Couldn't I just drill a hole in the cap and drop a sensor into the water? If I did, would it give me accurate temp readings? (Or are the probes even water proof?)
Sunday, March 15th 2020, 11:02pm
This will not work because these sensors are not water proof.
You can attach this type of sensor to the tubing and fix it with some aluminum foil and tape as isolation against the ambient temperature.
Accuracy should be quite decent. We used something similar for many years in the aquaduct series (external cooling unit).
mikegray
Monday, March 16th 2020, 8:37am
OK, will do. In fact, I actually have some aluminum tape that should do quite nicely to attach the sensor to a fitting, then wrap in a few layers of electrical tape.
caronen
Wednesday, March 18th 2020, 2:07pm
I doesn't even have to be a fitting - any metallic surface in contact with liquid will do. I've tested this method on waterblocks, radiators etc. The thiner the metal, the better but since there is lot of thermal inertia in any loop it worked quite well even on a thick wall of an aluminium Aquatube reservoir.
And if you don't mind some 20-30 seconds lag in temperature reading it can even by a PVC/Acrylic tube.
Also, I would focus on a propper contact with the metalic surface and would't bother much with thermal insulation unless your sensor receives some airflow where it is mounted (but then it means that You should place it elswhere anyway :)
This post has been edited 1 times, last edit by "caronen" (Mar 18th 2020, 4:50pm)
