• 12.11.2026, 06:09
hugemon
Mad fun with software sensor haha :) (+Some suggestions / request)
Wednesday, April 8th 2020, 4:30pm
My experimental setting for maintaining Ryzen 3900X boost clock.
The output will be set to 45 when boost clock = 3900Mhz, below 45 if boost is higher, and above 45 if boost is lower.
(So the radiator can be sped up to maintain the PBO boost clock)
It does work but don't expect +100Mhz results. I can achieve 3950Mhz-ish if I set the target clock to 3950.
Request : Can you make average / maximum / minimum function with multiple inputs?
Getting max value from 12 core clocks is so messy right now :)
eisbehr
Thursday, April 9th 2020, 12:40pm
Can I ask why are you doing this?! I don't get the point of this "mess". ;)
hugemon
Sunday, April 12th 2020, 9:14am
It has no point and that's the point. :P
I run Prime95 when I'm not using the PC so in order to maintain 3900+ boost clock it requires somewhat aggressive fan speed. (lower coolant temp.)
However, when I'm using my PC normally the PBO can usually achieves same clock speed with somewhat higher coolant temp. (= lower fan speed, quieter system...)
I could just make two profiles and switch between them or have fun with virtual sensors. One afternoon I chose to do the latter... :rolleyes:
phuzz
Thursday, April 30th 2020, 6:10pm
I ran into similar fun trying to get the highest single core utilisation, but at least I only had to do it for 16 threads ;)
Seconding the request for a single function that can take multiple inputs and output the maximum (or minimum etc.)
Friday, May 1st 2020, 4:15pm
If you want the exercise in the Virtual Software Sensor, then sure, but if you just want the busiest core/thread, it can be had straight from HWiNFO.
