• 06.10.2026, 20:23
knacker
Splitty4RGBx & Corsai QL fans
Friday, April 24th 2020, 2:43pm
Do the newer QL fans work with the spllity4 & Farbwerk 360 as I have a couple of QL fans left over from a full Corsair build and would use them in a separate build that I have all Aquaero stuff
Ta
eisbehr
Friday, April 24th 2020, 4:47pm
They work, but you can only put two QL Fans on one Spitty4. Because each RGBpx channel can light up tp 90 leds. Each QL fan has 34 leds. So two can fully be used, but the thirs one has only 22 LEDs left. So it's not fully working. And if you want to configure each led part on it' own (front outer + inner, back outer + inner) you need a mass of led controllers. So you might run into limitations of your Farbwerk. That belongs to what you want to do.
But basically, it works. I have 14 QL fans connected to AC products. :)
knacker
Friday, April 24th 2020, 5:11pm
Thanks for the response- I think I'll give it a miss then :D
