• 18.11.2026, 02:39
Easy01
[SOLVED] Aquasuite X 1.7 not recognizes farbwerks 360 on AMD
Thursday, May 7th 2020, 11:47pm
I have recently purchased a farbwerk 360 led controller, but when I wanted to install aquasuite it says there is no USB device detected.
I also have a vision display and that was detected and works flawlessly. So the wiring is fine.
When I check the device manager I can see the farbwerk 360 at the usb devices. What is even more weird that I have tried it on two other computers I have an old intel system and there it was worked as it should and get recognized without any issues.
But when I tried to use it on other 2 amd systems it was not recognized by the aquasuite software. On one of the 2 amd systems even has a fresh windows install where aquasuite was the first and only thing that I have installed with no luck.
Does anybody has any idea what could cause this and how could I solve it?
I am using windows 10
The tested not working system specs:
X470 asus prime motherboard
ryzen 2600 cpu
AB350 asrock motherboard
ryzen 3400G cpu
This post has been edited 2 times, last edit by "Easy01" (May 9th 2020, 5:42pm)
Easy01
Saturday, May 9th 2020, 5:39pm
I have figured out a workaround.
I have exported the Registry files that belongs to the 0c70 ID from my Intel system where the farbwerks 360 was recognized properly.
and re-registered them on the systems that couldn't recognize the farbwerk 360. System restart (Important!)
And now it works like a charm on both of the AMD systems where it was not detected before.
