• 05.11.2026, 09:08
realmmoto
Filter fitting Size?
Wednesday, May 13th 2020, 10:51pm
Need help to find out what type & size of thread is on these fittings. I have had this filter with stainless steel mesh, ball valves. The new version is stander with the G1/4 thread—the one I have not sure. I have never used it because of that. Is there a cross over for G 1/4?
https://drive.google.com/open?id=10yWvI6…TDonBWxHHK3dOvb
realmmoto has attached the following files:
  • AC_Filter 6.jpg (28.01 kB - 144 times downloaded - Last download: Oct 3rd 2026, 8:42am)
  • AC_Filter 7.jpg (53.32 kB - 136 times downloaded - Last download: Oct 28th 2026, 5:49pm)
  • AC_Filter 8.jpg (57.67 kB - 139 times downloaded - Last download: Oct 17th 2026, 3:00pm)
  • AC_Filter 9.jpg (29.06 kB - 148 times downloaded - Last download: Oct 31st 2026, 9:34pm)
This post has been edited 6 times, last edit by "realmmoto" (May 15th 2020, 5:16pm)
realmmoto
Tuesday, May 19th 2020, 7:55pm
I just wanted to pass this info forward to anyone that may have this same question as I did. I did reached out to AquaComputer support as well to see if they had an idea what I needed. They did reply, and also provide a solution for me thank you and appreciate the support. :)
Here is there reply:
Hello Antonio,
this seems to be an early variant that used G1/8 fittings.
The thread of G1/8 fitting has a diameter of about 9.6mm while for G1/4 it is about 12.9mm.
You could get G1/8 fittings to match your tubing size or you have to use a G1/8 to G1/4 adapter.
kind regards
Sven Hanisch
Sven Hanisch
Vertrieb/Sales
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
