• 29.11.2026, 05:52
Tasky
Cutting RGBpx strips
Saturday, May 16th 2020, 4:12pm
Hi all,
I've been looking at the RGBpx strips, and seeing in the description that they can be cut after each LED, after which no further strip can be connected.
However, the strips do have connectors at each end. So does this mean I could still use both halves, if I connected each half to a separate channel on, say, a Farbwerk?
Saturday, May 16th 2020, 5:09pm
No, the strips are unidirectional... they have an IN and an OUT, you should not connect an input to the port marked OUT.
Tasky
Saturday, May 16th 2020, 5:31pm
Roger that. Cheers, Info.
I suspected as much, but thought I'd check just in case!
