• 06.11.2026, 13:20
egawrangler
Connectivity Validation - please help!
Monday, July 13th 2020, 3:55pm
Hi AC Fans/Mods/Admins -
I've got an external water box cooling my PC, and I'm trying to minimize the connections down to just one cable between PC and waterbox. Please see the diagram below - is this a "valid" topology for the AC gear? I understand Splitty 9 can be used in aquabus mode and "splits" an aquabus connection. Thanks for any help you can offer!
https://www.dropbox.com/s/qfq36unfoohq78…nnect.jpg?raw=1
This post has been edited 4 times, last edit by "egawrangler" (Jul 13th 2020, 4:39pm)
Hufeisen
Monday, July 13th 2020, 6:22pm
RGBpx requires an USB Connection to work. RGBpx is not available on Aquabus.
You need to connect the OCTO with USB to the Motherboard, if you want to use RGBpx.
The D5 Next requires a temporary USB Connection for Firmware updates and initial setup.
After the setup is complete, you can remove the USB connection and control the pump with aquabus. (until a new Firmware update is required)
I dont know if you can change the LED color of the Pump when it is connected on aquabus only.
egawrangler
Monday, July 13th 2020, 9:03pm
Danke Hufeisen!
So RGBpx needs a direct USB connection via whatever device (OCTO in this case) to work. And yes, I'm aware of the need-USB-to-update-firmware requirement. Other than that, can you see any reason why the cabling in the diagram would not work? Thanks!!
Hufeisen
Tuesday, July 14th 2020, 9:26pm
The cabling should work fine.
