• 12.11.2026, 08:02
mstern
Sharing Flow Sensor Data
Tuesday, July 14th 2020, 5:46am
I have a High Flow Sensor, a CPU block with Vision, and a D5 Next. All are connected to USB and basically working. I have Aquasuite set up and it's as impressive (or more!) than I'd even expected.
I can see the flow rate from my High Flow Sensor showing under its device ("mps") and can also see it under the the Overview Pages as a widget if I want to add it -- so far so good.
I can't figure out how to call up flow rate (from the High Flow Sensor) on any of the display screens on my CPU block or on my D5 Next. Seems hard to imagine this is not possible. They just show 0.0 l/h for flow.
Any advice appreciated!
Tuesday, July 14th 2020, 7:14am
aquasuite>Vision>display>Datenquelle>neuer Sensor>"mps"(High Flow, not d5)>Sensordaten>Flow
Hope this helps, and sorry I'm too lazy to look up the English names, but it should be a direct translation
ps: I think you must have at least AS file server running, if not the AS.
pps: have no "Next" but should work the same way
This post has been edited 3 times, last edit by "EnigmaG" (Jul 14th 2020, 7:47am)
mstern
Tuesday, July 14th 2020, 5:16pm
Thank you! That solved the problem on the (CPU block) Vision display.
I still don't see how to do similar on the D5 Next display -- if anyone else has a suggestion, I'd really appreciate some more help. I can add the High Flow Sensor as a data source ("D5 Next" -> "Sensors"), but I can't see how to change data sources in order to select it for any of its displays under "D5 Next" -> "Display".
Tuesday, July 14th 2020, 6:19pm
Sorry i can not help you.
Thought there should be a display tab just like the Vision.
mstern
Tuesday, July 14th 2020, 9:20pm
Thanks anyway, EnigmaG.
There is a display tab, but the various pre-made panels under it seem only able to be turned on or off, not modified.
Saturday, July 25th 2020, 2:23pm
Can you send me a picture like that from the pump side, you made me curious.
mstern
Saturday, July 25th 2020, 4:00pm
As you can see, the interface for the pump display is different than the interface for the vision display.
Here.
This post has been edited 4 times, last edit by "mstern" (Jul 25th 2020, 4:06pm)
