• 05.10.2026, 18:52
johnnybra
New new farbwerk 360??
Monday, July 20th 2020, 10:53am
Hi all:
I've just received my farbwerk 360 and It seems to have a new layout with 4 more corsair-like conectors
Users manual is for old farbwerk, so I don't know exactly which type of led stripe can I use.
Thank you in advance
This post has been edited 1 times, last edit by "johnnybra" (Jul 20th 2020, 11:02am)
Monday, July 20th 2020, 11:28am
You received a brand new revision of the farbwerk 360. The additional connectors are connected parallel to the RGBpx headers and are the same type as at the mainboard.
We did this for more compatibility to other LED devices.
eisbehr
Monday, July 20th 2020, 12:06pm
Never saw that change before, but that is a relly nice addition! Good work!
johnnybra
That's really great!
And what about the ws2812 generic argb LEDs? Could I try this with an adapter without danger?
eisbehr
Monday, July 20th 2020, 12:09pm
All standard addressabe 5v leds should work on a Farbwerk 360, if you are within the limitations (like max led amount).
johnnybra
Monday, July 20th 2020, 3:57pm
Ty.
I'll try to adapt a generic strip with a compatible conector this afternoon.
And a last question: is aquabus port still not working with aquaero?
This post has been edited 1 times, last edit by "johnnybra" (Jul 20th 2020, 3:58pm)
eisbehr
Monday, July 20th 2020, 4:01pm
Afaik is the Aquabus on the farbwerk 360 currently still disabled/without any function. But who knows if this is changed too. ;)
Tasky
Tuesday, July 21st 2020, 11:04am
Aw dammitt......
I've only just bought the Farbwek 360 myself!!
BeachDuc
Wednesday, July 22nd 2020, 8:53am
Yup. This was a pleasant surprise. Thank you! Can you use both the RGBpx and normal header on the same channel?
Wednesday, July 22nd 2020, 10:09am
Yes, but it's not recommended and cause issues: The farbwerk 360 is monitoring the current of the LEDs due operation. If now two LEDs will be activated at the same address the current doubles and the farbwerk will monitor a abnormal current. So it is possible that it shutdowns for safety reasons.
eisbehr
Wednesday, July 22nd 2020, 10:32am
But that isn't new, correct? The "old" fw360 will do the same?
Wednesday, July 22nd 2020, 3:40pm
Yes, the hardware and software is the same. The newer version only has the typical mainboard plugs in addition.
