• 14.11.2026, 19:26
DirtyBear
MPS 400 flow no reading ! WHY ?????
Tuesday, July 28th 2020, 11:17am
Before the MPS 400 working great at my old setup
But after I switch to a new case the 6 LT did detect the MPS 400 but no reading
so please is there any way I could fix this ?? Please help
DirtyBear has attached the following images:
mditsch
RE: MPS 400 flow no reading ! WHY ?????
Tuesday, July 28th 2020, 11:51am
maybe your flow is too low because of (for exmaple) air in the loop? Your MPS is specified from 80l/h to 400l/h. When your flow is too much below 80l/h it will be the case, that it is showing "nothing"
DirtyBear
Tuesday, July 28th 2020, 7:03pm
If that simple I dont need to ask but thx
mditsch
Wednesday, July 29th 2020, 6:39am
then for helping, you should describe what you have made for to be sure, that you have enough flow in your build. What are with the temps of your componentes and water? Are they ok and on which level? If they are fine, then it could be, that your MPS is defect.
Bartdude
Friday, July 31st 2020, 6:05am
Another thing to check, when I installed my MPS400 I had a similar problem but mine was caused my a pressure build up within the loop. To fix it I installed THIS to the top of my reservoir.
This post has been edited 1 times, last edit by "Bartdude" (Jul 31st 2020, 6:07am)
