• 15.11.2026, 00:36
NEW: ULTITOP D5 MIRROR BLACK - Solid brass, minimum noise
Wednesday, July 29th 2020, 11:44am
The ULTITOP D5 is already one of the quietest D5 pump housings in the approved acetal version. Nevertheless, customers are always asking for an even better housing made of solid metal. The higher weight does indeed further improve noise damping.
We have taken this as an opportunity to produce an extremely noble version of the ULTITOP D5: The ULTITOP D5 MIRROR BLACK.
Our CNC-production manufactures this masterpiece from 1,5kg brass. It is then carefully ground and hand polished. The finished machined housing still weighs almost half a kilogram!
As a finish we use a new nickel coating: MIRROR BLACK. Depending on the angle of view and reflection, this creates a breathtaking appearance.
As with the ULTITOP D5, installation is very easy using a stainless steel bracket. This is easily attached to the ULITOP D5 MIRROR BLACK with only one screw. If the ULTITOP D5 MIRROR BLACK has to be removed, the holder itself can remain in the PC.
In order to eliminate the remaining vibrations in the smallest possible space, we trust in our proven ULTIDAMPER. These decoupling elements made of extremely soft silicone have been calculated by many simulations and offer the perfect decoupling for the pump.
The ULTI-DAMPERS have two inner cores of stainless steel, each with two M3 threads for mounting.
The high-quality retaining ring is turned from aluminum and is black anodized.
It will be available at a price of 79.90 Euro.
Scope of delivery: ULTITOP D5 MIRROR BLACK with holding ring, mounting bracket, set of ULTIDAMPER and screw set.
jesse.le
Thursday, July 30th 2020, 10:22am
Will there be a side by side dual D5 time soon - similar to the alpha cool unit?
https://www.aquatuning.us/water-cooling/…-dual-plexi-top
Thanks!
Flop Ysh
Thursday, July 30th 2020, 10:09pm
WOW Neat!
