• 11.11.2026, 21:46
pilotter
Octo and d5 Pump
Sunday, August 9th 2020, 12:09pm
So hopefully last question :D .
Can the Octo control the D5 pump of a https://www.ekwb.com/shop/ek-quantum-kin…pwm-d-rgb-plexi ?
will the pump be shown in aquasuite as fan or pump?
Also would Octo Aquasuite be able to control the RGB.
Technical specifications:
- Size (HxWxT): 365x120x86mm (with the mounting system)
- Capacity: ~435ml
- D-RGB connector 3-pin 5V digital LED header (Pinout: +5V, D, Blocked, Ground)
Pump electrical and mechanical properties:
- Motor: Electronically commuted spherical motor
- Rated voltage: 12V DC
- Power consumption: 23W
- Maximum pressure head: 3.9m
- Maximum flow: 1500L/h
- Maximum system temperature: 60°C
- Materials: Stainless steel, PPS-GF40, EPDM O-rings, Aluminium oxide, hard coal
- Power connector: 4-Pin Molex- and 4-Pin PWM FAN connector
Operational regime:
- PWM duty cycle: ~ 20-100%
- Default behavior: Runs at 100% duty cycle when no PWM feedback signal is present
This post has been edited 1 times, last edit by "pilotter" (Aug 9th 2020, 12:56pm)
k2viper
Sunday, August 9th 2020, 3:34pm
Yes, OCTO can control pump, but to control its RGB by it, you need additional "RGBpx to motherboard type" connector and appropriate RGBpx cable.
https://shop.aquacomputer.de/product_inf…roducts_id=3829
https://shop.aquacomputer.de/product_inf…roducts_id=3762
D5 will be shown as fan, but you can call it whatever you want on your custom overview page.
This post has been edited 2 times, last edit by "k2viper" (Aug 9th 2020, 3:42pm)
pilotter
Sunday, August 9th 2020, 5:01pm
thanks for your time :thumbsup: , order is placed.
