• 30.09.2026, 22:54
Lucky75
Splitty 9 configurations
Friday, August 14th 2020, 12:48pm
Hello Aqua Computer experts,
I need a little help with Splitty 9 and Active versions ...
What are differences and how to put jumper settings for 8 - 3 pin BitFenix 230 mm FANs (I think they are not PWM) ?
Did I need Quaddro here ?
Friday, August 14th 2020, 4:05pm
With 3 pin fans your only choice is the Splitty 9, both the Splitty 9 active and the Quadro/Octo only support 4 pin PWM fans. If your fan controller can support 8 fans on the Splitty 9 you have to check the manual of the motherboard or controller.
I can't say anything about the jumper settings, I don't use the Splitty 9.
Lucky75
Friday, August 14th 2020, 4:45pm
Thank You for your reply. So now I am sure that my planing is right.
I just need to connect all together and install software to configure all.
Lucky75
Friday, August 14th 2020, 4:50pm
Slitty 9 has one jumper between FAN mode 3-pin and aquabus mode 4-pin.
Hufeisen
Friday, August 14th 2020, 5:57pm
If you connect Fans to the Splitty9, you need the Jumper in the Fan position.
If the Jumper is in Aquabus position, the reading of the fan speed will be unreliable / not working.
Lucky75
Monday, August 17th 2020, 8:52am
Thank you, so my planning is perfect now.
Similar threads
