• 22.11.2026, 12:48
Phynicle
Can the d5 next pump control pwm fans independent of aquasuite software or os?
Friday, August 28th 2020, 4:08pm
Looking to simplify setup with an external radiator and 6 fans. If I have the d5 next pump, can it control the fan speeds based on water temperature without having to be connected to the main pc via usb for the aquasuite, ie preset profiles?
Alternatively if I can first connect it up and set profiles, then disconnect the usd, will the profiles operate independently from then on in controlling the fan speeds based on water temp?
Hufeisen
Friday, August 28th 2020, 6:06pm
Yes this works, if you use the water temperature sensor that is integrated in the D5 Next.
This post has been edited 1 times, last edit by "Hufeisen" (Aug 28th 2020, 6:08pm)
Phynicle
Saturday, August 29th 2020, 8:14am
Cheers and thanks!
So as long as I set up the profile initially, then I can disconnect the usb and the profile remains saved onto the d5 unit
k2viper
Saturday, August 29th 2020, 12:26pm
Yes. Again, if you plan to rely on water temperature, you have to use D5 NEXT's built-in water temp sensor only. Other system sensors would not be available since you're planning to disconnect pump from system.
