• 12.11.2026, 03:38
stingray
aquaero temps
Saturday, August 29th 2020, 12:29am
hi
how do you determine the temp that the aquaero is running at?
thx
stingray
Saturday, August 29th 2020, 2:33am
17 views,,looks like im not the only one that dont know where to read the actual temp of the aquaero itself :thumbsup:
Saturday, August 29th 2020, 3:58am
stingray
Saturday, August 29th 2020, 5:23am
i wouldnt think these are whats used when controlling the temp of the actual aquaero when water cooling it.
in older software all 4 couldnt be used
Saturday, August 29th 2020, 10:19am
So my AE5 has 2 temperature sensors, fan amplifiers 1 & 2 and 3 & 4.
I'm not sure if I understand your question
This post has been edited 1 times, last edit by "EnigmaG" (Aug 29th 2020, 11:16am)
Saturday, August 29th 2020, 3:31pm
The only direct control you have, is if do NOT controll the fans using the PWM mode.
In that case you could set a Controller Curve to increase fan speed as the Fan Amplifiers increase in temperature. vss_sample.jpg
Note to aqaucomputer: it would be useful to have more than two inputs for the Max/Min functions
