• 31.10.2026, 21:56
Tanquen
My 6 Pro has a High and Low aquabus port
Wednesday, September 16th 2020, 11:04pm
My 6 Pro has a High and Low aquabus port but even the latest PDF manual from April 2020 don't show the Low one. The manual that came with it is from 2019 and has no aquaero 5 info.
Wednesday, September 16th 2020, 11:17pm
Ignore the aquabus low(speed) port. It has nothing to do with aquabus anymore. It was reprogrammed years ago to serve as a second flow sensor port (for 3-pin flow sensors). I also doubt that you have any aquabus lowspeed compatible devices. There were only two of them: tubemeter and multiswitch.
Tanquen
Thursday, September 17th 2020, 2:35am
Did I get old stock then? I just received the 6 Pro and again the manuals don’t show that port.
I do have the 53257 in line temp sensor and did not know what port to use. Sounds like the high port as it has 4 wires?
I do see that the manual.
Please note: The “Flow 2” connector may also be labeled as “aquabus low” on
the device. The function of this header is determined solely by the current firmware
version of the aquaero. Starting with firmware version “2010”, this header can be
connected to a flow sensor irrespective of connector labeling.
This post has been edited 1 times, last edit by "Tanquen" (Sep 17th 2020, 2:47am)
Thursday, September 17th 2020, 2:58am
Yes, it belongs on the high
That's exactly what Shoggy says, it doesn't matter what it says, is is Flow 2.
