• 12.11.2026, 18:55
bradley
Aquastream Problems
Thursday, January 6th 2005, 1:48pm
HI all...
I purchased an Aquastream pump and connected it all up, filled the system then removed the jumper block. The pump ran ok for a little while then stopped suddenly, the red LED started flashing 4 times and it refused to start again...
I then went out and purchased a second aquastream pump from a local UK stockist and i connected the new aquastream controller onto the old pump to see if it would work, as this would save me draining and disconnecting my loop...
The pump worked again, I was very happy... But only an hour or so later the same thing happened... 4 Flashes from the red LED and the pump wont go...
Can anybody suggest anything i can do?
any help or suggestion would be very appreciated
Bradley :(
PhilS
Re: Aquastream Problems
Thursday, January 6th 2005, 4:05pm
Maybe the pump itself is crashed :-/
NikoMo
NikoMod
Thursday, January 6th 2005, 5:03pm
you have to change the whole set. pump an controller.
i think that the pump is damaged, and causes the damage at the controler
bradley
Thursday, January 6th 2005, 5:41pm
thank you for the replies...
I do believe the problem to be the pump... As it has know ruined 2 controllers...
I have tried contacting AC but have recieved no reply...
major23hh
Thursday, January 6th 2005, 5:58pm
mmhh, may be the support is a bit busy again. just send the email you allready have sent again to support@aqua-computer.de
bradley
Thursday, January 6th 2005, 6:17pm
Quoted from "0800-S-P-A-N-I"
ok will do that...
regards
Bradley
NikoMo
NikoMod
Thursday, January 6th 2005, 6:47pm
and please notice:
ac needs sometimes 2 or 3 days before you get a reply.
when you have none in 5 days please contact dino by instant message.
<--- this link (IM)
