• 16.11.2026, 17:50
Mrevind
(Question) D5 with USB not discovered by Aquasuite
Thursday, November 5th 2020, 9:52pm
So I´ve been tryin to find the answer to this question but no luck yet.
I bought a Aquacomputer D5 with USB pump second hand, but never used so when it arrived it was still in its original package. The pump is around 4-5 years old.
The pump is fine and works but I have no luck getting it to be recognized by windows or Aquasuite.
I cant get any reading of the "alarm" plug either for rpm of the pump.
When I first started to fill the loop the pump acted like a normal pump and started and stopped with the psu turning off and on. After I plugged the usb and got in to windows it need the usb power to start.
I´ve been reading that you brake the usb aquaero bit of it if you plug the cables wrong when installing it, but I didn´t plug them wrong.
So my question is; is the usb part dead? Or is there something else that makes that makes the aquasuite not work?
And how can the usb bit of it be dead when it needs the usb to be powered?
Can the usb part of it be replaced?
Thanks for any answers.
Mr E.
This post has been edited 1 times, last edit by "Mrevind" (Nov 5th 2020, 9:56pm)
Mrevind
Tuesday, November 10th 2020, 6:27pm
So a small update.
I have since I posted here tried the pump in another pc with no luck.
I have also double checked that the correct .net framework is installed. I now believe that the pcb /card is broken.
Is there a possibility to get a new one from Aquacomputer?
Thanks for all the replies.
JasonMorris
Wednesday, November 11th 2020, 12:45am
Can windows see it in device manager? Have you tried a different USB connection? Can you verify that your USB connection is working with something else?
This post has been edited 1 times, last edit by "JasonMorris" (Nov 11th 2020, 12:46am)
Mrevind
Monday, November 23rd 2020, 7:32pm
Well to answer; no.
Windows sees nothing.
Also tried it in another computer and it still does'nt shoe up.
I have ordered a new controllerboard from AC.
So we'll see
