• 29.09.2026, 13:44
ReX_ITA
AQUASUITE X29 PROBLEM
Saturday, November 28th 2020, 10:59pm
Hi!
I just bought a Farbwerk360 and installed Acquasuite x27. I probably made a mistake authorizing the update to x29 (the check for the update to "insider" products is active by default and I didn't notice it).
The Farb360 firmware was updated with the suite, now preventing the downgrade to x27 as the firmware is not supported.
Unfortunately I have very strange problems regarding the programming of the controller (flash, wrong colors, blocks in the effects, no multiple profile...), which to diagnose whether to be attributed to hardware or software problems I would like to try with a stable version of acquasuite
Is it possible to do something?
Many thanks!
Omnipotous
Sunday, November 29th 2020, 3:17pm
i believe all Products can be reset to factory Setting meaning you can re update to X27 firmware once you have stable X27 installed.
Sunday, November 29th 2020, 3:41pm
You cant go back to X 27.
Currently we have no issues with the x29. Restart your system and make a clean install with X29 Version.
