• 08.10.2026, 16:28
Syndra
D5 Next Pump connection to Aquaero 6 PRO Gigant 3360 question
Monday, December 28th 2020, 9:01am
Do I need to physically connect the D5 Next pump to the Aquaero 6 PRO PWM connections inside the Gigant 3360 to control the pump? I plan to connect two pumps to the Aquaero. The only problem I can see is the distance between the pumps location in the case the the internal PWM connection inside the Gigant 3360. I would have to use extensions? Will there be any problem having a D5 Next Aquacomputer and a Singularity Pumps? Should I just use two D5 Next pumps instead? I want to make sure I have everything I need when I build this computer in one or two weeks. I don't want delays having to wait for extension cables or finding out two different D5 pumps isn't a good idea.
This post has been edited 1 times, last edit by "Syndra" (Dec 28th 2020, 9:03am)
Monday, December 28th 2020, 9:11am
The D5NEXT is not a simple PWM pump, it has its own control including water temperature sensor, virtual flow sensor, fan control for PWM fans and RGBpx control. It connects to the motherboard via USB and to the power supply via SATA connector.
The control of the pump speed and the fans via the Aquaero is additionally possible via an Aquabus cable, but not necessary.
Whether it makes sense to have two different D5 in the system I can not say, I get along with one very well :-)
D5NEXT Manual
Translated with www.DeepL.com/Translator (free version)
This post has been edited 1 times, last edit by "Taubenhaucher" (Dec 28th 2020, 9:15am)
aveamurechi
Monday, December 28th 2020, 10:32am
Quoted
Since I am also interested in the D5NEXT pump, my understanding of your statement is that the USB connection to the MB allows pump control via the Aquasuite SW. The Aquaero module connected via Aquabus cable is nice but optional. Did I get that right?
Thanks
Monday, December 28th 2020, 10:38am
Quoted
Thanks
Yes.
Use the linkt to the mamnual ;)
